Part Numbers for ISS?
t2ch
Charlottesville, Va
Anybody got the part numbers for the ISS and new bearing from GM?
Mine is rattling terrible since I put the new shocks on.
Try greasing it. Get a spray can of grease, crawl under the dash, cut a small slit in the boot, spray in some grease, turn the wheel, and do it again a few times. This problem is just as, if not more, common in the GM cars, ala my SSEi. I haven't had the issue, but many people have temporarily solved the problem by greasing it, and a can of grease is way cheaper than a new ISS. By temporary, I mean about 6 mos.
I had both of theses parts installed and still had to go with the hose clamp to stop the rattling.
19153614 ISS
88963617 Bearing
I have already installed the hose clamp, still rattles. It has gotten worse since I put the Bilsteins on after Christmas. My Yukon does it too. It has the green bearing which is supposed to be the updated version I thought.
The clunk I have sounds like it is comming from the drivers side wheel. It does it when I hit some choppy bumps. This is the ISS clunk isn't it? The reason I think it is the ISS is because my Yukon does the same and only has half as many miles.
When I had mine done they did it under warranty. If your out of that its a $55.00 chance here http://partszoneonline.com/index.php.
