pin outs and diagrams
bud9899
Recruit
SE, GA
PMD pin out:
A - FI Control from PCM - Grn
B - FSol+ drive from FSD - Red large
C - Closure grnd to PCM - Blk small
D - +12v switched power - Pnk - same as ESO solenoid power
E - FI Signal to PCM - Red small
F - FSol- drive grnd for FSD - Blk large, also attached to the top of the Inj Pump ONLY - NO MOVE - NO EXTENSION -TOP OF THE INJECTION PUMP, ONLY - PERIOD!!!!!!!!!!!
Idiots guide to PMD wires
A- Green wire from puter. Tells it what to do.
(Fire the injectors)
B- Red wire goes to back of pump to the poppet valve solenoid
(Triggers the firing)
C- Black wire goes to puter so puter has a ground like PMD
(Good grounds make happy puters)
D- Pink wire goes to ignition and the electric shut-off solenoid
(That silver shiny cylinder thing up front thing) 12volts or better on a good day.
E- Another red wire, goes to puter and tells it what the pulse width is to the puter.
(So it can throw up a code when the pump or PMD is shot. 35 or 36 take your pick)
F- Another black wire, goes to back of pump to the poppet valve solenoid
(grounds the solenoid so it will fire when the PMD sends it some juice)
Resister goes between E and D just so the fuel output can be tweaked just a little.
Thanks to gmctd and diesel pro for the info
vac diagram for s motor
Here's a pic of the vac diagram
Fuel injection lines
Converted it to a jpeg
Engine controls diagram
I found all diagrams for our trucks. Working on compiling them in a jpeg format so I can upload them individually with titles stating what each post contains. This should be good. Hopefully someone finds a use for them.
engine controls repost of enginecontrols1
It looks like I'm gonna have to do something different when converting them to jpeg's so the resolution is clearer. Working on it.
Ac controls
All these diagrams were selected to go with a C2500 truck with a 6.5T.
horn controls
a lot of folks like to add a larger more intimidating horn to there truck, here's the wiring diagram for it
power distribution circuits
here's a few more
charging and starting circuits
starting and charging circuits for those pesky battery problems
Well I hope someone finds some use for the diagrams. If you need a different year or other schematic let me know, if I can find it I'll post it. Sorry the conversion from pdf to jpeg didn't turn out real clear but I can read it on my wore out monitor with my wore out eyes so I hope you all can too.
Peace
i would ask that the source of these pics be stated....as posting wiring diagrams that may be from a haynes or something, could be a copyright infringment, and was not allowed on TDP or the Place, and i'm sure it won't be allowed here for long either....as it leads to sites being shut down....so i just ask that you state a source, and i realize i'm not a mod but i do this in the best interest of the site
