took me a while to get back with this cause I was out of town but here it is:
Truck starts and works great but sometimes re starting after killing the engine it does start but dies after 5 or so seconds, purging air out of the fuel filter and t valve will make it purr again.
- Year:1994
- Truck model and class (ie: c2500) c3500 DRW
- Automatic or Standard Auto
- Mileage: (indicate miles or km) 128600 miles
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) remote mounted fsd
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? no clue.. can someone tell if i provide the vin?
- Ambient outside temp: (indicate *C or *F) any temperature
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) regular PEMEX pump diesel (thats all we have here in Mexico)
- What fuel additives are you using? none
- Where are you located? Sabinas Hidalgo, in the great state of Nuevo Leon, Mexico
Air filter 3 months
- Fuel filter 3 months.
- CDR Valve? i dont know what this is
- Coolant – last flushed/replaced at: dont know
- Oil – synthetic/regular, changed at regular rotella 15- 40 @ 125500 miles
- Batteries – state of charge, (matched set) replaced at match set 3 months old
- Battery cables and grounds (removed, cleaned and tightened): battery grounds and cables are alright
- Glow Plugs - how many miles on them? Im thinking it has the same plugs it came with from the factory. What type? oem maybe
- Injectors - last changed not changed yet as far as I know.
What were you doing when it happened? nothing
- How was the truck running fine before this problem appeared? as good as always
- Has this problem ever happened before? it happens every day or two
- Describe any related factors that might be part of the problem. one of the fuel lines had a leak, my mechanic cut the leaky part and put it back on, he said it was kinda stretched now so that might be where air might be entering the fuel lines
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) Yes And? code 78 but that's a different story.
Does the engine start? Yes but sometimes it wont after killing it.
1b] Does the engine crank over? Yes
1c] Are your batteries fully charged? Yes
1d] Have you removed, cleaned, and tightened all battery connections? Yes
1e] Does your Wait to Start light come on for a time? How long? dont have a wait to start light
1f] Does your glow plug light come on? Yes For how long? bout ten seconds or so, depending on how cold or warm the morning is
1g] Do you see smoke from the exhaust while cranking? What color? no smoke
Can you hear your lift pump working? Yes
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? usually yes, but theres bubbles coming out after it dies
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? yes
2d] Loosen an injector line and crank the engine - does fuel come out? yes
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? very seldom do i hear a vacuum
3a] Location of PMD (on pump, on intake, remote mounted) Remote
3b] Condition of Extension harness (if used) Vendor or Homemade? good condition, bought from a vendor
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. good
3d] PMD Make: Dipaco
3e] PMD Age: 3 months
Do you experience stalling only when hot? yeah, pretty much
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) no it just dies a few seconds after restarting
4c] Does pouring cool water over the IP seem to help with restarting?
theres no need to pour water to restart
Is stalling momentary (engine recovers)? not unless i purge all the air out
4e] Does SES light come on when engine hiccups? no
4f] Does cruise control quit working when engine hiccups? my cruise control doesnt work at all
4g] Does re-starting seem to reset engine, restoring cruise and power? CC doesnt work at all
4h] Changes to dash lights or instruments during stalling events? none
5a] On cold start, does upper rad hose get hard before engine warms up? no
5b] Any bubbles or oil film in coolant overflow tank? no
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? no
5d] Excessive white smoke from exhaust on cold start? no
5e] Excessive black smoke from exhaust under hard acceleration? no
6a] Do you have gauges? no
6b] Maximum boost under load? dont know
6c] Have you added a performance PCM (reflash) or Chip? no
6d] Have you changed exhaust / downpipe / crossover? bought truck with a very loud dual exhaust tip
6e] Wastegate – mechanical or vacuum? vacuum, stock
7a] Single or dual thermostats? not sure, single I believe
7b] Have you replaced them lately? Manufacturer of replacements? no
7c] Have you pulled and cleaned Radiator and coolers lately? no
7d] Have you replaced the fan clutch? Manufacturer of replacement? no
7e] (winter) Have you tested your antifreeze? Good to what temp? havent tested
7f] (winter) Are you using a winter grille cover? it doesnt get that cold here.
I've had this truck for about three or so months, bought non running after it had been sitting for over 8 years, the previous owner described the issues he had with the truck I looked them up on the internet and figured it would be the PMD, bought the truck and brought it to my mechanic, he did some checking on it and told me that the previous guy had really messed up the wiring and managed to fry the ECM a new ECM and some more checking later we figured the PMD was indeed the culprit, we started it on a blend of really old and new fuel without any problems. I once dropped to fuel tank to check if the float was stuck or something cause my fuel gauge is always on Full, and when i turn the key the orange needle goes further to the right beyond the full mark.. not knowing to check for snot or stuff like that I just saw that the float thingie wasnt stuck so I put everything back together
