chrisk1500
- Messages
- 875
- Reaction score
- 1
Now next time you drop the tank, let me know if the sock is blown off....
Matt, now that you have have good flow to your IP....maybe you should consider doing Feed The Beast...
Spoke to Todd at Heath D. about this after I ventured into this my self he felt it didn't have much value unless you was drag racing.. out of my territory.. its done and there must be reason that so many do it...
I just read between the lines..
The relief must feel for you good Matt, well done..
I would think that heavy pulling or plowing would be in the same category as drag racing. Glad it's running good for you Matt. Leo
If the sock is off, maybe a good idea to put a filter before the LP?
Tubing cutter you can pick up on the plumbing isle at your local hardware store. Double flaring tool from auto parts store. Both are useful for making brake lines as well.
Here's a picture:
