SUBURBAN99
- Messages
- 13
- Reaction score
- 13
I did a complete frame off with new rebuilt motor & tranny . All new suspension everything new. Ran great put about 8,000 miles on with all the oil changes and filters. i has a the first PMD go out which was on the pump. The place that did my build said if I relocate the PMD it would cancel my warranty. after the original PMD failed I unpluged the PMD leaving the old one on the pump relocated it. Everything ran great. The other day I went back through all my grounds to make sure theu had metal to metal contact beacuse once in a while i would turn the key and nothing would happen. I replaced the ingition switch still the same situation. So after redoing the grounds the engine was running and then stop like turning of the key. it stated and then would turn off. now nothing the starter just cranks but it will not fire.plenty of fuel up to the high pressure pump. lossen one injector line at the injector no fuel dry as a bone. changed out three different PMD's that are brand new out of the box same situation. pulled the solenoid fuel shut of used anther one without the plunger no change. also plugged in the PMD right at the pump no change. any help be great. I'm thinking my high pressure pump has failed.
