Problem: Heavy shudder upon braking
Big T
Fullerton, CA
This is on my ‘99 Suburban. Have a shudder from the right front upon braking. It increases the heavier I hit the brakes.
This was happening before the broken tie rod incident which was on the right front. I rebuilt the front end with new ball joints, tie rods, ES poly bushings on forged replacement LCAs. It passes the dry park test with no play on the tie rods in the knuckles. Ball joints are tight. It drives smooth and tight at highway speed, but this brake shudder persists.
Today I replaced rotors, pads (close to wear bars) and calipers, but the shudder persists. I am now at a loss as to what is causing this, so I’m reaching out for help.
Only thing I know can cause that is warped rotor.
Jack it up, remove front tire/wheel.
Hold a center punch real close to rotor and turn the rotor.
See if the punch drags on the rotor.
Could maybe also be created from an out of round rear braking drum.
Old rotors did it and brand new rotors are doing it. Do not feel it in the pedal nor at stops at slow speed.
I'd be putting a scanner on that and check the ABS readings .
ABS light is on. Occasionally it goes off and the system works. I had similar thoughts. I do not have my Tech 2 with me. Tests I did over the weekend indicated the ABS pump motor is shot. I’ve ordered a reman ABS unit which is all that you can get now. I could pull a plug and disable the ABS altogether.
That would be a quick easy elimination process.
Unplugging the ABS did not change a thing other than my ABS and Service 4wd lights turned off.
I continued my drive over to Wayne at Eagle Watch Automotive and we went for a test drive. I showed him the shudder on heavy braking. He asked me to brake more moderately. Then he asked me to do the same from a slower speed. He looked at me and said “although it vibrates here up in the front, I think it’s from the rear and it’s probably a warped drum from heating up when just the one was locking up.” He asked to drive it so he could show definitively. Driving about 10 mph he pulled the parking brake handle, then braked moderately and you could feel the wop, wop, wop. He said “It’s definitely in the rear. Change the drums and you should be good.” Did not take more than 5 minutes.
By pulling the parking brake handle and braking moderately, he was able to isolate the braking to just the rear wheels. So when we felt the wop, wop, wop, we knew it was in the rear. It was the left rear that was locking up because I installed the brake shoes incorrectly on the right side with the front piston rod dropped down and not engaging the front shoe. So I was getting minimal braking out of the right rear, and the left rear was doing all the braking and locking up. Conclusion was that I overheated and warped it.
I ordered a new drum from Napa to replace the left rear, figuring that’s the one that is warped. It will arrive tomorrow and I’ll get it installed when I’m done with the day job.
By pulling the parking brake handle and braking moderately, he was able to isolate the braking to just the rear wheels. So when we felt the wop, wop, wop, we knew it was in the rear. It was the left rear that was locking up because I installed the brake shoes incorrectly on the right side with the front piston rod dropped down and not engaging the front shoe. So I was getting minimal braking out of the right rear, and the left rear was doing all the braking and thus locking up, overheating and eventually warping.
