Lmao, true, i over worry alot.
Just hope it lasts me, ill more than likely be leaving the service next year, if it can last to NYC and beyond, id be happy
If you can swing it and are going to install new engine oil cooler lines, install an engine oil bypass filter.
I install a T in the return line brother engine oil cooler to supply the bypass filter and return to the engine oil fill neck
If your gonna drive like you stole it at 85+ on the freeway, you might look into a gearvendors overdrive unit to install. that will give you a highway cruising gear while in 2x4. that will help with the MPG's and lower the engine RPM's when going that fast! my 93 has one with a 4l80e running 4:10 gears and gets 1900-2000 ish RPM at 70mph while running the smaller 245-75-16 tires.
It's hard justifying the investment at a $4k, but if you drive across the country a lot, it will pay for it's self sooner. sometimes you can find them used on marketplace and ebay. it's one of those "nice to have" things to put on your wish list.
