It’s not regular wire. It is fuseable link.
If you can shorten it up & crimp on a new end, do that. Otherwise you’ll be spending more money than was in the game plan.
Cable ties to hold them out of the way incase they do pop off, and the heat sheilds are the way to go.
Ill try that
Where could I possibly find a similar link/cable though, should that not work? I assume autozone?
I couldn't tell in your video, but if it's that what looks like a rusty sensor next to the GP. that is your coolant temp sensor for the gauge. is that still working?
The coolant sensor isn't there actually, its on the driver side of the radiator, it's a small wire with a fitting that I never could figure out how to put in the new radiator, so it just sits there.
Ill look more in there when I can
If that's the #8 gp, it should be fairly easy to get at with the inner fender removed. just be careful removing the GP from the head if it's been in there any length of time. unthread and pull straight out, don't bend or twist if it gets into a bind. last thing you want is a broken gp tip in the cylinder.
go back with the delco 60g's bosch are known for the connector tabs breaking off from what I've read online, and delco 60g's are the only ones that won't destroy your engine upon failure.
Only buy the ACDELCO 60G glove plugs from a known vendor.
I have a friend that cussed 60G glow plugs - I really believe he got some counterfeit.
I used to buy them at Autozone.
I don't know who sells ACDELCO 60G glow plugs now
Ill try that
Do a continuity test back to the glow plug controller.
I think somebody, maybe @Glagulator posted the type of wire and connector needed not terribly long ago.
I'm old, so that means in the last 4 years.
There are good glow plug wire kits to be bought
Depends on your budget and if you want to go to the extra work
I always thought the wires going to each GP were standard wires with a high temp insulation and the fuse link was at teh GP controller where all 4 wires joined together into one about 6" from the GP controller. there are two of them with 4 wires each, one for each side of the engine.
Guys, I lowkey messed up
Which hose goes to which port? My dumbass removed botb hoses without marking which end goes to which (from block end to radiator end) which is the correct flow pattern?View attachment 95306
if the fitting sizes are the same for both, I really don't think it matters which direction the flow is through the oil cooler. are you installing a new cooler or re-using your existing one?
others will chime in soon to say the correct flow.
View attachment 95307Air Filter gasket on the top of the intake went out, anyone know what are the measurements for it? Im trying to find a new one
are you planning to make your own gasket? if you can remove the two studs from the intake, lay a piece of printer paper over the opening and run your finger pressing on the edges firmly to create impressions in the paper. then pull the paper and cut it out using a razor knife to make you a template. draw it out tracing the template on some gasket material and cut you a new gasket. I personally would use a light amount of gasket sealant (NOT SILICONE) on one side, intake or filter head side so it will stay in place and you can still remove the filter head and not harm the gasket.
