Even if that heals it, have the fluid and filter changed - not flushed: changed, which involves dropping the pan for the filter change - they'll try to talk you into a flush because it's more lucrative, but a '98 is sorta long in the tooth at 20yrs old, and as X# owner, you likely don't have any idea of the condition of the fluid and filter that currently resides there - have them let you look at the detritus in the bottom of the pan - if there's lots of brown\black wet powdery stuff, that's band and clutch material, and you should consider a rebuild
If the fluid doesn't have a burned odor, and the powder is only slight, they can go back together with it and adjust the bands for improved driveability
Next would be the throttle position sensor, which is like the volume controls on the old radios, B4 digital - they would get scratchy after awhile, and lubing them would stop the noise for a few days, but replacement always cured the problem - the throttle position sensor is a variable resistor just like those volume controls and has the same failure symptoms - when they go scratchy, the trans tries to respond - they're 'scratchiest' at normal traffic speed positions, around 30-35mph, 45mph, 55mph, 65mph
