MrMarty51
Thats one of those that runs on about as much pressure as a shop vac puts out the exhaust side ?
The true low pressure unit ?
Yep, 9.5 psi which is perfect for HVLP guns.Thats one of those that runs on about as much pressure as a shop vac puts out the exhaust side ?
The first one of those I had seen was about 30 or more years ago.Yep, 9.5 psi which is perfect for HVLP guns.
For the ‘99 it appears to be Indigo Blue Metallic: WA9792.VIN is no help. RPO shows 55U.
WA 228A looks to be correct.
Since I’m painting the full truck, that should be good enough.
hdpaintcode.com
It’s the Indigo Blue Metallic paint code WA9792The color in this picture match it?
Vehicle Color Code Database
What are the paint codes for? We have them all here. Every manufacturer from A to Z, plus fleet color from Semi's and National Standard company's paint codes. If we don't have it, we will get it.hdpaintcode.com
Look at the 1999 Models.
More info here:
