I’m watching this thread, and I will check for pinched wires, a few years years ago I changed the transmission, and intermittent running, but long cycles of running. I drove to Toronto and it hasn’t run since. My truck is set up similar to AK. There’s pressure to new ip, fuel exits the transition from hardline to hose at back of engine, How much return flow should come from the return line. I need to check by the sender next. Can a bad starter relay crank, but not start engine? Sorry to hijack, but same issue, all sensors function as they should. No mist from gp holes. I did cooka battery coming home from Canada. Side post developed leak and boiled off. Replaced those and took a new alternator off shelf to eliminate voltage regulator, till I get old one tested. Today I will check pinched wires and see if flow returns to tank. OP , again sorry for hijack. Can a bad starter relay allow crank, but no start? I haven’t visited in a long time, it’s good to see everyone still here
