n8in8or
Have you inspected the linkages to make sure the springs aren’t broken? From what you describe, I wonder if one of those could be broken.before I replaced my air box on my 95 with the ac on I had a little air blowing from the defroster and the floor with a majority coming out of the front vents. after replacing that portion of the dash that had the flapper doors everything worked like it should. though I did replace the actuator motors too. I do recall that one of the doors is spring loaded and even now if I turn on the ac and go right to high blower fan, the air will stay blowing out of the floor. I have to turn it on with the fan on low and give it a minute then go to high fan and it works as it should. my blower fan seems to create enough back pressure in the box to hold the doors so they won't do their thing.
