Husker6.5
Yup, those "shorty" style castle nuts. I've kept and reused the original, taller OEM castle nuts on ball joints, idler arms and tie rod ends just for that reason, or just kept the old ones if the new joint came with the taller castle nut.You can see the issue in the thread that DieselAmateur linked. I have pasted pictures from his thread below. The hole in the stud is about .200" from engaging the castle nut. The nut isn't short, it just isn't lined up at all. I'm going to shim it with some washers and call it a day.View attachment 87996View attachment 87997
100% on corporate bean counters! Somebody should contact customer service at Mevotech and complain about them making unsafe, faulty product because they do not include the proper castle nut for how the stud is drilled to properly retain the nut.
