trouttrooper
Big Blocks ROCK!!!
Hoping to get some insight from someone smarter than me. 2002 Sierra 1500 4x4 w/ 5.3, 310,000 miles. mechanically this truck still runs amazing, everything still works, and no rust. I've owned it for about 4 years now as a "first time" vehicle for my kids. I've been tinkering/fixing some minor things before I hand the keys to my next kid. oil leaks, bad o2 sensors, broken plastic pieces here and there etc. I've been driving it off and on the past 4 months listening for any issues that need addressed, when a couple weeks ago I went to start it and it was dead. I mean dead dead. battery was less than a year old. got it to take enough charge to hold above 12 volts. drove it around then went through all the fuses testing for voltage drop. didn't find anything. got a new battery, tested fuses again for voltage drop, again nothing. 2 days later go out and it's dead again, sitting at 5 volts. got it to take a charge so it holds above 12 volts but of course my battery tester says it's only able to produce 300 CCA now. drove it last night and noticed the volt gauge on the dash was over 14 volts. put a meter on the battery and it reads 14.7 and doesn't fluctuate when I load and unload the electrical system while the engine is running. my charging tester also said its too high, so I'm thinking bad alternator overcharging, but would that kill a battery within 2 days? can an alternator be a parasitic drain when the engine is off? no check engine light or any codes using my bluedriver code reader. I don't see any obvious loose cables or wire corrosion anywhere.
