I'm looking for some blue & yellow, 5/16 & 3/8 heat shrink ring terminals / eyelets
jrsavoie
Recruit
Rural Clifton, Illinois
I'm looking for some blue & yellow, 5/16 & 3/8 heat shrink ring terminals / eyelets, with the larger Outside diameter rings. 10 or 20 each.
The rings on the terminals I had were about the same size as a washer. 5/16 was probably close to 5/8" diameter
And the 3/8" was probably about 11/16.
I forgot to measure them. I didn't think to. I thought I'd find them within a couple minutes of searching.
I used my last on Sunday.
I think these will work. I think they're a tiny smaller than what I had. The others were about the size of a serrated but.
I believe these will work
Well, that didn't work out. I should have checked the measurements before ordering.
The 15mm OD sounded right. But is considerably smaller than what I want / had.
I'll have to measure the OD on what I have here.
I'm returning these.
