Thanks again for the input. I ordered my '93 truck new from the factory and instructed the dealer to leave the factory plastic on the carpet, where it remains. It has always been garaged, has it's original paint in excellent condition (except for the driver's door, which was replaced when a doe ran into it at the crest of Wolf Creek Pass), and its grey cloth interior shows virtually no wear. It is a dark blue/green color and has a long bed with a factory liner. It has 175K pampered miles and has been extraordinarily reliable until this tranny fiasco.
If my recollection from reading THEFERMANATOR's posts is correct, attempting to put a '94 or later 4L80E tranny into a '93 truck is the equivalent of trying to force a square peg into a round hole, and will result in hard shifts, potential damage to the tranny (and truck), and other problems, all of which seem to have taken place with the shop's three attempts to replace my now missing original tranny (which, incidentally, I had requested that the shop have rebuilt before discovering that it had been sent off as a "core"). The shop is in the process of making its third warranty claim and appears to be in denial about the need to use a compatible (91-93) tranny, and will continue t repeat their mistakes, and it appears that I will have to put my truck in storage while they try to figure out what to do. I now need specific advice/instructions to gently guide the shop in the correct direction. I was hoping that THEFERMANATOR would chime in on this.
Regarding photos of my truck, I have several on my phone, but have not yet figured how to post them here.
One last thing - In July I was in the process of delivering the truck to my nephew in Wisconsin then the tranny downshifted to third gear and would not upshift to fourth. After checking the fluid, which was clean, I was able to trick it into upshifting into fourth by turning the ignition off and on and made it back to Flagstaff from Albuquerque and told the shop that I suspected an electronic versus a mechanical issue. They insisted that it was a mechanical problem and after over $7K and three transmissions I am now told that it will take at least six weeks to locate another transmission. Go figure.
