Alright doing some detailed testing starting with Transfer Case Connector Switch C1:
I believe this connector attaches to the switch buttons at the dash. The # of pins is an exact match and shape, but the color coding of the wires does not match. For example, the G (ground) pin has a Red wire, when it says Black above. The F pin has the black wire.
I tested with the plug off and the only combo I got voltage for was G to A at 8.0v. B, E, H got 0.1v; C, D, F got 0.0v.
I then performed tests 1 and 2 from the following:
1. Select 4WD low, test voltage backprobed at the transfer case motor drive circuits, C1 terminal A to terminal B. Should be battery voltage for as long as the 4WD Low indicator is flashing.
2. Test voltage backprobed at the motor brake control circuit C1 terminal D. Should be battery voltage until 4WD Low is selected, then voltage should be 0 or near zero while the 4WD Low indicator is flashing.
3. Scan the encoder switches status. Test voltage backprobed at the encoder switches circuits. Compare to the information in tech tips. Compare when selecting 2WD, 4WD High and 4WD Low.
4. Repeat tests at Transfer Case Shift Control Module connectors.
5. Inspect C131 and C132 connectors, terminals, wiring for damage, corrosion.
6. Test wiring from Transfer Case Shift Control Module to in-line connectors, to transfer case encoder motor. | |
| Tech Tips: | |
1. A to B in 4 Lo got me voltage Fluctuating from 2V to 6+V when it should be full battery voltage.
2. Terminal plus Ground to under dash got 8.0v in 2 Hi when it should be battery voltage and 8.0v in 4 Lo when it should be 0 or near Zero. Obviously, this is problem.
3. Not sure where the encoder switches are? Is this the other plug on the dash switch/buttons?
Still need to do 4, 5, and 6.
