valyidol
Active Member
Hi
And again 6.5 and again problems.
1994 Tahoe. 6.5 with DB2.
The first cylinder is not working. White smoke on startup. Unburnt fuel. The engine is shaking.
After about 5 minutes, the smoke almost disappears. The engine runs smoothly. The cylinder stops working again when the engine reaches operating temperature
The compression is great. The nozzle works great. Glow plugs works.
I removed the valve cover. There is wear on three pushrods. I changed pushrods, rockers, lifters. Nothing changed.
I removed and disassembled the head.
Here's what I saw: firstly, there is no washer under the spring of the intake valve of the first cylinder, and secondly, all exhaust valves have a very large play.
Why is the first cylinder not working? Is it because of the washer under the spring?
Or is there another reason to look for? Could it be a camshaft or IP?
