Never cycle the key ON-OFF-ON "a lot" - the PCM is an Intel-based microprocessor controlled computer, just like your PC, with some AMD stuff in there, also - imagine how your PC would react to that scenario, banging the power on-off-on, and the resulting state of functionality - knowing that that is the usual result of frustrated ownership, it is highly unusual that people don't have any more unexplained electronic failures than is reported, here
The reported symptoms equate to ignition switch deterioration, as well as other possible failures - first step towards resolution is reliable switching function - faulty connections, whether in connectors, terminations, or switches, gives same symptoms as faulty active devices, such as sensors, controls, and electronic modules
That '96 Sub is rather long in the tooth, here in '09, and that switch has operated many thousands of cycles per year - need the ignition section of the switch to make good electrical connection to the ESO and FS and FSD\PMD on the Inj Pump, Lift Pump, Glow Plug Controller, and PCM B4 you can proceed with any other required troubleshooting
Pristine power and grounding connections are equally as important, and being much cheaper to fix, should be addressed first
Battery capacity ranks right up there in importance, and since cold weather bleeds mature (read: aged) battery power, easy to check, expensive to replace, still needs to be done, if you've required one winter jump already
