Your probably right. Cheap auto parts topped with covid qualityProbably made of Chinesium.
I used the green wire from the Hayden controller to the purple pressure switch in back of the compressor. The other wire to the switch is hot spliced into the clutch wire. Only two wires connected to the clutch going to the controller. Here’s some pics. I’ll have to look up the diagram for the controller and draw something up on how it’s all connected but it’s fairly simple@dbrannon79 care to show a pic or two of how you got the electric fan clutch wired in to kick on with your a/c? I have all the components for the ev fan clutch and think I can gather how to wire the basic fan clutch and controller in. But despite all the talk of trinary switches in other threads I still have no idea how to make the a/c and fan clutch work together, I do much better with visual learning
Nice diagram. Simple to say the least. I’ll be saving that to the notes in My phoney so when the time comes it’ll be right handy.@DieselAmateur Here is a partial diagram I drew up on my pc using images online. I need to get the fan clutch pinout, maybe someone can help me with that. but I only used two pins for the controller, I think it was pin 1 and 2 for fan 1 and ground.
as soon as I get the pin out info on the ev clutch I can add to it showing which wires to use plus I think there is an rpm wire one can connect and see the percent of lockup the clutch is at too!Nice diagram. Simple to say the least. I’ll be saving that to the notes in My phoney so when the time comes it’ll be right handy.
