Starter bolt size
Stoney
Elmira ny
Can anybody tell me the correct starter bolt to use for a 1997 c 3500 6.5 turbo diesel... One of the two big bolts that hold the starter in fell out,. So I need to know the length the thread all that stuff.
Just barely got done doing this on my mock up block
Mine was broken off about 1/2" deep in the block, I'm assuming where the threads started. Anyways I used a transfer punch to get a center mark then drilled and used an easy out. Came right out. If you're careful you might be able to use the bolt hole in the starter as a guide to get started and then pull the starter and finish drilling
mine broken the exact same place yours did about half an inch into the block...What do you mean use a pic and spin it out?... I literally just put the starter back in with the one bolt. Figured I would slide one of the new bolts up in there and hold it in place while the wife starts the truck...
