Don't forget a new set of pads and shoes with that order. If you indeed had a leaking rear axle seal then the shoes on that side are gear oil contaminated and are shot. If you were having caliper lock-up issues, the pads have been well heated and are more than likely glazed. Also, a new set of the updated design caliper pins for each side would be a good idea, too. When you do the rears, take the adjusters and disassemble them and wire brush the begeebers out of the part that threads into the housing, use a shotgun cleaning kit brush to clean the inside of the adjuster and make sure you have any corrosion/brake dust gunk off of them so the parts are bright and shiny and check for any deep pitting of the adjuster screw threads from corrosion, then when you go to screw the adjuster back in, liberally apply anti-seize to the threads as you screw it back in, then wipe off the excess when it's bottomed out. This will keep the adjuster from hanging up. Also, don't forget a light schmeer/dab of high-temp moly grease where the brake shoes rest against the backing plate pivot dimple. Are you installing a new parking brake cable at this time, I can't remember if you cut the old one? If so, now's the time to do it and before installation, pull the cable out from the sheath as far as it goes, grease up the cable really well and move it in and out several times regreasing it each time. Do that at every end of the sheath. After install wipe off grease from the exposed cable with a clean rag/paper towel. This will not only greatly extend the life of the E-brake cable, but will make applying/releasing the E-brake much easier and smoother in the future.
I know, this is probably the umpteenth time you've probably changed out shoes/pads through this whole fiasco, but you should make sure that you have fresh friction material if your going through all of this if for nothing else, safety's sake.
