Tinker
Active Member
I think a lot of you have done this mod so maybe you've come across this issue. I didn't see anything similar in a search of the archives. Note: I've contacted Heath but it's the weekend and I'm a little impatient to finish this, so figured I'd ask around.
I don't have clearance to install the bell crank for this Turbo Master on my GM4. The crank hits a flange ear for the exhaust 90. I know I can grind away at that flange or come up with some other rigging, but I'd rather not. This is supposed to be a 20-30 minute bolt-on and the part isn't cheap. Have any of you come across this?
Do I just have a franken-turbo? Do aftermarkets have a shorter wastegate lever shaft? Plate says GM4. Doesn't look to me like it's ever been replaced.
![IMG_20210410_124448[1].jpg IMG_20210410_124448[1].jpg](https://www.thetruckstop.us/forum/data/attachments/52/52800-fabc58bcb1c3acc6375901d4a89226f9.jpg)
![IMG_20210410_124217[1].jpg IMG_20210410_124217[1].jpg](https://www.thetruckstop.us/forum/data/attachments/52/52801-ba97ec4148e46e598894509b7c6cbcf7.jpg)
