I got some pics of the start of the mods....
Status
Not open for further replies.
You thought about clear corners for the front headlights? And I'm not sure if you did or not, but you also might want to take off that lowest air dam/valence..half tons look way better without it IMO
I'm not the biggest fan of blue, but the dash at night does look sweet. I see what you mean about turning that Edge display backlight down a little. That would be very distracting while driving. Can't wait to see the bumper on it.
geez bigblock... give me time here... The IRON BULL BUMPERS will be installed here next week probably. They are here I just need to get the coated and installed... waiting for the lift to be on...
I will take some pics tonight when it get dark of the gauges and the edge....
Glad you cleared that up. I wasn't sure what kind of bumpers you were going to run with and was about to fire off a PM to ask. ):h
Looks good... keep us posted with the progress.
Pretty sure you can clear the corners..
you can but you have to heat the assembly up and break the seal and then break the amber part out of it and then reassemble it and try to get a good seal.... which you will never get it perfect and moisture will end up inside and they will yellow out very quickly
If you say so :rolleyes5:
Whens the lift gettin put on that sonbitch?
Status
