Given that there is no performance camshaft options for 6.2/6.5L engines, another avenue to increase air flow in to and out of the cylinder by increasing valve lift and lengthening valve openness is a higher ratio rocker arm. Has anyone ran the Harland Sharp 1.6 ratio rocker arms and what results did you get from them? Is there enough clearance between piston and valve on a stock long block to facilitate this, or should this only be used with thicker head gaskets or shorter low compression pistons?
