Anyway, the story continues. As I had ****ed up pretty much everything I tried to work on in the holiday period, I decided, I might as well give the exhaust a go as well. I have red countless posts about people ripping of the heads of the bolts on the crossover, so I decided to let time, rust penetrating oil and heat help me. I even invested in a impact gun to try to loosen the bolts.
Then, a friend of mine gave me THE BEST TIP EVER:
50/50mix of acetone and atf was supposed to be the best rust penetrating goop ever. Okay, I decided to give it a shot. Bought it and a steel oil can to mix it in. Let it work for a night, and then my plan was just to heat it up, let it cool down, and apply more to let time work for me. I just had to feel the bolts. DON`T YOU THINK THEY CAME LOOSE! ALL 6 bolts on the crossover came out quite easily, and I got all the four nuts on the down pipe connection off as well. This is a miracle mix!!
I tried to divide the exhaust without hurting it, but at the end I gave in to the angle grinder. At least I got it out. Here laid out next to the new 4" Diamond eye exhaust:
Got under the burb and started mounting the exhaust. It was a bit tricky being alone, and the blizzard didn't really help either, so at some point in the evening I gave in, and left the project unfinished. At least - even though its not finished, its at least not ****ed!
So that's basically the end of the rant when it comes to my Christmas advedtures. I've been three weeks away now, heading back home on Thursday, where I will have return lines, turbo shaft and the new casting for the starter waiting for me - so hopefully I´ll be able to get it up and running fairly quickly. I scored some cheap Ac Delco 60g glows the other day, so I´ll be doing the glows while I have everything opened up. I didn't have to, as I did the glows a year ago or so, but it feels good to know that they are 60gs. At the moment I have a mix of Bosch duratherms and some dieselrx plugs that I luckily found locally when all the electrical connectors on the Bosch plugs kept breaking off.
So here she is - waiting for me to come back and finish the work. Can't wait to get home!!
