Pruittx2
Been around a bit
So the Burb at 200K has decided to start hard or not at all when temps are over 80f after a shut down of 20- to 120 mins. Ip getting hot and out of spec. pour bottle of water on IP fires right up. I have located a New only 1000 mile IP a fella had installed then truck over heated for other reasons, blew engine so he parted it out. I can pick it up for $550.
Now at 200k and running great, no issues over the last several thousand miles, I'm gonna R&R that pump, so while in there, Who's with me on the
"I should do the timing chain and gears while that close?"
"I should do Harmonic Balancer while there?" <--- It looks perfectly fine, with no degradation of the rubber.
truck had new H20 pump and hoses when purchased in 13 @ 125k. But figured I'd do those too.
Valve covers pretty leaky so I'll do those as well.
What am I missing, or should also be considering??
