May have found a new wireless temp probe
Sand
Canada
Im going to grab one of these ffro Home Depot.
Weber iGrill Mini App-Enabled BBQ Thermometer
200hr battery life. Smartphone app.
Ill put it in my transfer case to start. Then move it to my diff and even throw it in my geared Hummer hub.
Monitor temps from the cab wirelessly.
Its only 50 bucks....
1/8 npt cable gland tightened around the probe. Then threaded into the transfer case. Possibly at the drain plug. It not for permanent use. Just to see where things operate at. My transfer case has a cooling loop from the transmission. I think it acts as a transfer case "heater" most of the time. As well im curious what temps my hubs run at under load.
