X2 on that.Man THAT is a mess!
Records are made to be brokenI hope you ordered a new PS pump otherwise you ARE better off with a non-prior-failed and patched pump from a junkyard. Do flush the system from the low oil and add a Magna X In-Line Magnetic Power Steering Fluid Filter to catch what else is left. Unless the system got dusted from a burning up pump then you simply replace everything in the system... My record is 5 rebuilt POS pumps in a row.
Thanks for the filter tip, picked one up today. Got the cheapest pump I could find because this ones the first in line for trade in on a newer truck... hopefully.I hope you ordered a new PS pump otherwise you ARE better off with a non-prior-failed and patched pump from a junkyard. Do flush the system from the low oil and add a Magna X In-Line Magnetic Power Steering Fluid Filter to catch what else is left. Unless the system got dusted from a burning up pump then you simply replace everything in the system... My record is 5 rebuilt POS pumps in a row.
