Thanks for your reply.
Those are very impressive numbers. I've read some good things about Kennedy's tunes. but I have ZERO experience with EFILive and obviously no personal experience with Kennedy's tunes, so I'm intrigued.
I know nothing about how to use EFILive either.
Can you give us more information about your experience?
John is a top notch guy. He helped me out in every way that I asked him to and answered every question that I had, before and after the sale; and believe me, I had a lot of them.
Can you tell us more about your truck and what mods you have?
I have an'07 CC 4x4 LT2 with a 4" turbo back MBRP exhaust, 265/75/16 tires on factory wheels, PPE aibox mod, and I am using an Edge EVO for gauges. I have used a Predator, EVO, Hypertech Max Energy, and the Duramileage ECM on this truck, and the JK custom tune is the best I have run so far.
Have you been running this Kennedy tune for a while?
I guess I have been running it for about -3 months.
Did you have him recalibrate your speedometer for the larger tires
Yes and if so, how accurate is it now
It is dead on by my GPS and do you correct your numbers for speedo error?
No need to Are these numbers hand calculated or from the DIC?
hand calculated If hand calc'd, how accurate is the DIC in your truck?
For some reason, the DIC is variable. Sometimes it reads high, sometimes low, and sometimes dead on. I think it depends on how I drive it. On hiway trips, the DIC is usually dead on or even a little low. On daily driving and towing it is usually high. (My experience with aftermarket programmers has been that they throw the DIC way off and they are generally quite a hassle to get good accurate speedo calibrations - but I don't know how EFILive handles that.)
Are you able to fill your tank to the same exact spot every time when you have checked your fuel economy to ensure good consistency? I know that many times this not possible due to fuel foaming and other impatient drivers waiting to use the pump.
I fill 'er to the brim every time.
Did you have John re-flash your ECM or did you get one of his replacement ECM's and keep the original stock unit?
I bought the replacement ECM so I could go back to stock for dealer visits. How is the driveability (i.e. performance, shifting, EGT, smoke, etc.)
Drivability is at least as good as stock. Shifts are firm but smooth. There is very little smoke. EGT's are very close to stock, maybe a little cooler empty and slightly higher while towing. The power is felt throughout the rpm band.
Are those number with the A/C ON or OFF?
Both.
What kind of tire pressures are you running? What tires? Load Range?
I am running Hankook 265/75/16 load range E inflated to 75 lbs.
Have you upgraded your transmission?
No.
Are you using any kind of fuel additive?
I usually use Diesel Kleen Power Service in the silver bottle.
How do these mods/tune compare to the time when your truck was pure stock?
I enjoy driving the truck more so now than when it was stock. When I want to go it goes. Also it holds the gear longer now than when stock. In other words when pulling a hill empty, and running 55 it would down shift to maintain 55, Now it doesn't. I'm talking about hills that require the truck to downshift not just any hill. Sounds a lot like what t2ch said huh?
Finally, how much was the tune? (Feel free to PM me if you don't feel comfortable posting this information)
Check out his website. http://www.kennedydiesel.com/
Sorry for all the questions, but those numbers are very appealing.
Thanks for your time and patience with my questions.
No problem and you are more than welcome.
