Might shoot Devils Own a email and see what they say on the subject....
They assure me that there are no problems as long as the proper amount of fluid volume is used and can verify multiple 6.5L's running high % mixes with not a single problem.
With a diesel engine (Rudolf Diesel, another German of the 1800s, lent his name) the air is compressed more than 20:1, raising the temperature in the cylinder to more than 1000 degrees F, then the diesel fuel is sprayed into the cylinder and is ignited by the heat.
Auto-Ignition Temperature:464°C (867.2°F)
Granted the temperatures would get hot, but wouldn't the addition of the water lower the actual combustion process since the IAT's would be lower, thus putting off the auto-ignition temperature of methanol and making it more suitable?
Yeah, well, I got a little lost in it, that's why I just asked a simple question
Throw in the heat gain from architecture in the combustion chamber (IE: pre-chamber mouth "lip") creating hot spots and you can easily be in and out of autoignition temperatures even with the WMI rockin' full blast.
So it's a maybe?
So, spurred on by the thought of not knowing why . . .
Now, it's been a while since I've done thermodynamic calculations and I had to make some assumptions as well. There's lots of variances and opportunity for error here and it changes on a multitude of variables. I also assumed adiabatic compression . . .
. . . but wouldn't the addition of the water lower the actual combustion process since the IAT's would be lower, thus putting off the auto-ignition temperature . . .?
But, gotta ask, how long did it take to re-learn the slide-rule??? :hihi::hihi::hihi: (Sorry, could not resist)
