An update on this. Problem persists. On hard accelerations up grades, the turbo will hit 7 psi boost and drop off to 0 psi and it stays there at 0 psi. Turbo will not generate boost until engine is shut down and allowed to cool off. Then the cycle of boost them loss repeats itself.
Wastegate solenoid is new and that code has disappeared.
Nothing has been done with grounds, tank, tank sock, lift pump. It's my son's tuck and I don't drive it. I only advise on repairs.
An ATT has been ordered from Leroy. I am concerned that the issue is signal related and tied into IAT sensor. In other words, it's sensing high IAT and opening the wastegate and dumping boost. He said that it lost boost and blew black smoke going up the Cajon grade this past weekend. Doesn't sound like it's defueling, just losing boost.
Again, I'm not driving this, just relaying the symptoms. I hope that the ATT makes this all a moot point.
