Tryn2 follow WarWagons post, this is way down the list of trying to track it down and more of a generic help for the future. Your situation is probably too strong for this technique if you have not done it before.
never heard that one explain please
The wire with an electrical charge will create a magnetic field. Where the wire has a short in it the magnetic field will stop.
Put in a self resetting circuit breaker in place of the fuse, the higher amperage fuse the stronger the magnetic field be generated and easier to trace, but don't get carried away and melt a harness down. Start passing the compass over the wire slowly starting with the fuse block tracing the wire, You will see the magnetic Field by the sweep of the needle. It will go from pointing North to pointing a different direction because of the magnetism in the wire.
Slowly pass the compass over the wiring harness moving a few inches at a time. When compass needle no longer deflects in the different direction that is where you will find the short. This takes practice because as the short causes the auto resetting circuit breaker to heat up and disconnect, the compass will change direction back to north every time it loses power. So when the needle changes directions, stop moving the compass and wait to make sure if it was the circuit breaker tripping or if that is the location of your short.
The best thing to do is to build a fake wiring harness out of two or three pieces of scrap wire cover it with towel on a bench and practice it, you'll start to see how to use it as a diagnostic tool.
You can also use an inductive amp meter Or an inductive voltmeter,to do this, But you have to be careful not to exceed the range on the meter. If you exceed the range on it for too long or doing it too many times will pull the magnetics of the meter out of calibration.
Like many things in life this is the cheaper way out, and therefore is harder, takes longer. When fighting electric problems the best electronic tracking tool you can get your hands on is your friend. The Mac tool that I mentioned works of this principle but has a power generator to do it safely so you cannot burn out the electrical circuit, And the inductive pick up for it is more delicate to read the EMF generated by the wiring to give you better readings and work much quicker.
