Keep in mine oil squirted in the GP holes will burn as soon as the compression comes up.
The GP holes are so small as to not be a concern.
From the low mile military engines I got:
(They run fine without the recommendations, but, it is easy to do while the engine is out.)
I would do an minor overhaul. Deglaze the cylinder walls and put in new rings. Check for cracks in the mains.
Rings will help with blowby.
Even better is gapless rings that will make near zero blowby and keep the oil way cleaner. Expensive but worth it.
You should not need bearings or need to remove the crankshaft to do this.
The cylinders that were left with a valve open tend to get a little rust. These are the ones that benefit the most from deglazing and new rings.
New seals for the crank, new HB unless you have a good one.
Replace the timing chain.
Head studs or new TTY head bolts.
Rocker arm buttons.
