vacuum pump
busdriver75
Busier than hell...
NW Ohio
i need a new vacuum pump because apparently i can't just take it out and replace with a shorter belt. where's the best place (read as cheapest place) to get one?? i need one ASAP.
whoever comes up with the best price, i will send a 6 pack of beer in the mail.
They sell aftermarket ones (electric) for hotrods. Wonder if you can make that work get some free HP ta-boot. Why do you need one anyway?
i've got california emissions on my truck, meaning vacuum pump. i heard you can just take them out and plug the line, meaning your EGR valve will stay closed then. but i'm not sure.
you should be okay with out it in there. just by the appropriate belt. same routing except where the pump is now it goes straight through instead of around the pump. if it is just not functioning and not noisy leave it there.
Pardon my ignorance having a non emission Lb7. :(
Thanks for the excellant info!
sounds good to me. i'll be yanking it off tonight and getting a shorter belt in the morning.
you get it off?? how much of a pain is it?? mine's in the shitter too, need to pull it. just wondering how much of a pian it was and whether or not the short belt worked. tired of fk'in with this thing.
thx
i've got an appointment at the dealer tomorrow ot get my injectors checked. i'm assuming they are going to tell me my vacuum pump is bad as well. i believe its supposed to be covered under the 5 year/100K emissions warranty (which expired about 60 days ago). if they don't offer to replace it for free, i'm going to tell them to ignore it and i'll worry about it later (pull it off myself).
i'll let you know how it goes.
