Hi, I'm new to this forum!, I'm in the UK and have at last picked up a 6.2 engine for decent money.
Having removed the sump I'm very pleased not to see any cracks, I'm sure the will be some small cracks when its pulled right down, but so far the engine looks ok to rebuild.
Quite fancy fitting a turbo on this, a question about fueling, the pump is ajusted for extra fuel but this means the fuel flow is rpm calibrated & not boost referenced.
With the popular turbos used on these engines, is the a cruising rpm that is not seeing boost but is running rich?.
I'm looking at economy but want some decent power as well!,
One other thing, can a 700R gas gearbox be used on a 6.2?, can you get a torque converter suitable for diesel torque power?
thanks!!!
thanks!!!
