If you ever decide to power the rear quarter windows your wiring is almost done already. All you need to do now is to run the power output from the rear window switches to the rear quarter windows as the switches already have power to them as part of providing power for the front window switches. The hard part is in removing everything from behind the front seats, the jumpseat and all the plastic panels, and fabbing mounts for some window motors. I used rear quarter window motors from a Pontiac Montana.
About the bezel around the Kenwood, yes I'm meaning the dash colored piece that surrounds the vents and the radio. So you found it on e-bay. Do you have the info on who the seller was, maybe a link to his site?
I found powered, heated, lighted, and extendable mirrors on e-bay that look exactly like the tow mirrors found stock on the 2000 and up GM pickups and are supposed to be a plug-n-play for the 90's era pickups. What the sellers don't tell you is that to have the plug for all these options you have to have a 98 or 99 vehicle (plug is not to be found in earlier rigs). I found all the wiring plugs I needed from later 90's rigs,the sub harness, and wiring diagrams and made an add on loom to accommodate the mirror. I've seen the write ups for the Dodge tow mirror and almost went that direction, until I found the mirror I now have. Either way you will be faced with some major wiring unless you opt for no power options.
I fully understand about the money situation. I'm on disability and had to do some real scraping to come up with the funds to do the mirror swap.
I don't get up to the WW area very often, but next time I do I'd like to meet up.
Don
