Guys,
having some weird issues with my 98 suburban - have been through the whole new PMD/harness thing and no changes - no codes being thrown at this point.
I am set to change the CPS and then the OS if the problems do not resolve.
I have the CPS loosened and free in its hole but can not get it the last 10mm out to remove it as the PS pump is fouling it.
On the other forums i have been advised to loosen 3 bolts and the PS should come loose - i have done this (and found two more besides) and have a tiny amount of movement but nothing near what i need.
When looking at the casting that is bolted to the engine that supports the AC coompresser and the PS it looks like a bolt through job from the front and hence why i can not get much movement.
Does anyone know how to drop the PS pump out of one of these ?
Craig
Craig
