buddy
Active Member
I think there is a trade off.  Holsets are know for fast spooling, possibly because they use a larger radius housing and the way their blades are designed.  Mitsubishi may be using small radius housing because they are cramming them in tighter spaces, and may need more blades to spool, or the blades arent as wide.
I do not see how a 12-blade fan would be more efficient than a 10-blade in general. The purpose of the 10-blade on the Holset is to achieve better flow. But depending on the design a 10-blade could have just as much surface area as another manufacturers 12-blade. And the pitch on the 12-blade could be less so that it doesnt slow the air as much. Comparing a Holset 12-blade to a Holset 10-blade, the 10-blade will alow more unrestricted flow.
Since I was originally comparing the Holset H1C to the Holset HX40, I thought it was a reasonable explanation how the smaller housing could be running similar drive pressure values.
