Paveltolz
Доверяй, но проверяй
Yeah, mine is pretty much a daily driver because I can. Sorry GM Guy, you're not getting this GM-8 any time soon. It's too pretty and polished inside and out.
Found a local source for rod bolts. Produced by Pioneer Inc, they were available to order through RPM Machine Performance Part in Cedar Valley Ut (Google map puts them about 3000' off the desert floor in the hills).... Anyway, ordered four sets. One for the 635R, two each for Ted's 6.2 projects and one additional set for him because...well just because.
Additionally, spoke with one machinist about the rod bushings and it was going to be a coordination issue with shipping and timing and a little discovery on both our parts. The machinist who does Bill's day to day work and had started this whole goose chase with his simple question, "are you going to use these 'special' bushings" finally answered his phone and press them in and hone them to the correct specs for under $100 for the whole set. Done deal.
Ordered the "Yates Bushings (still don't know the real name), Fluid Damper HB, Pulley, and Tork-Thrust #3 cam (don't need the valve springs as the ones sent back with the reconditioned heads are correct for the application (just saved some $$ honey) and discussed time tables and options with Todd.
As for turbo's, I've tried a couple of times to express my thoughts and questions but it always comes out wrong in the proof reading stage so suffice it to say, I may try a larger turbo at a later time, as Ted mentioned (I have an ATT on the shelf here that has a suspect housing) but, it will have to wait a while for when the motor is broken in and things calm down for myself and others.
