silentkillzr
So i get this truck, 5 mins later starter takes a shit. its a 6.5 TD. 1995 motor. The starter mount on the block broke off so the PO took a longer rod to the exhaust above because this chunk of the block broke off where the outer starter bolt mounts in. It worked sortof. I went to go re-'fix' this messed up way of mounting it and i cant get the starter to go back in the way it was, working. It just spins or grinds, i got the motor to turn over once, but this mount keeps allowing the starter to cock away from my flywheel. I do indeed have the bracket on the front of the starter to the block on also. I am almost out of answers. I'm debating what i should do about this, Take it to a shop and pay i have no idea how much they would charge or ???
If you guys could throw me some options or thoughts lemme know. Ill post pics tomorrow.
