racedaymechanic
Active Member
I Got the relocation done today, its pretty simple and will work with my Battery Cable Kit, First thing to do is take the PS - and+ cables off the Battery take the + of the drivers side to keep from shorting out. No take out the PS battery, Air Box and Battery tray, There is a ground attached to the fender take that off also, now remove the Heavy felt insulation, put the box in place setting on the inner fender, and with a sharpie mark the holes that need to be drilled using the box as a template
I also took out the air intake tube as I am putting the old airbox where the battery was
If you remove the RF signal light you can see the air intake there is one 9/32 screw in the upper r of the pic that has to come out to remove the intake
heres a better view of the intake thru the signal light hole
These are the bolts that go in from the back side to hold the Battery Box in place
A piece of tape on the backside of the strap will hold it until you get the nuts started
Heres a view of the bolt strap going in thru the old intake hole its tight but you can reach your hand in there
Heres what it should look like when the bolts are thru
Put the box back on Tighten the nuts and reinstall your battery, I did have to bend the lip up a little for the Battery to fit and you will have to reroute the Rad tank line
