First I want to thank you guys for fixing my lift pump and EGR/Vacuum pump issue. :thumbsup: :thumbsup:
I just removed the egr valve, put an inch&threequarter freeze plug and bolted over a steel plate on it. Test drove it to make sure I didn't get a whistle. Nothing bad happened. I was wondering if you guys could tell be where the chip is at where can I get one programmed for an EGRless engine?
Is there anything I can do about the soot build up in the manifold short of pulling it out and drowning it in GUNK?
