small sandblaster advice
schiker
Pendleton, SC
I am pondering getting a sandblaster (small one $100-$300 max) to clean up the rims on my old '72 tractor. I have a flat and last time the rim was so rusty it cut the intertube several times inflating the tire. Shop had to line the rim with duct tape to work.
I was thinking of cleaning it and repainting it. Then other small clean up jobs busting rust on attachments and repainting as needed. I have just a small home air compressor 115V so low CFM.
Anyone ever used a pressure washer sandblaster wand attachment? I have an electric 1800 psi ~2 gpm pressure washer.
How much difference is there between a name brand like ALC and the Northern Tool house brand. Price is $100 difference or more.
I have used cabinet blasters at previous employers (glass bead) but not sure how much media I used. What is a good size unit for a homeowner?
Yeah, I think I understand that I will be limited by CFM of air compressor and moisture is a problem with clumping media (the 2 big issues).
I have a filter/moisture seperator but not a dryer or absorbent filter. Think that will be enough?
Do the siphon feed really feed ok in a home / infrequent type set (low budget set up). When not being used I figure empty and cover up. Store media in a tote wrapped in a heavy trash bags tied shut.
There was a guy down the street that seemed to have a side business sandblasting and he did not seem to have that fancy of set up. I think a few tires I do myself would pay for a my investment for what he charged me to sandblast the center/hub of my rear wheels.
I figure to sand some and not blast off everything but more clean up and get the nooks and crannies etc of irregular and curved parts with blaster.
the biggest problem with my siphon set-up is mess. hard to reclaim/filter used media. i have a small 100# compressor, it cycled a lot but kept up. i have another 10 gallon tank plumbed in. a cabinet is nice for a lot of reasons, filter media, less mess. but not as portable and uses a little more room. for small jobs, go to harbor freight. there are some cheap ones, cabinets or siphon. if you want an investment to use for years, get a good one and pay for it. it will last and yon can blast enough to have a side business.
............... moisture is a problem with clumping media (the 2 big issues).
Do the siphon feed really feed ok in a home / infrequent type set (low budget set up). .................
i had a problem with clumping, all i had was a filter. driers are the best way to go and if you do a lot, cleaning the head will get on your nerves.
On badly rusted rims like that(i had a few) i just used a wire wheel on the angle grinder to clean them off before painting,cheap and effective.
Works just as good as sand blasting me thinks.
Good call. Thanks for the suggestion. I bought a twisted wire wheel for my 4.5" electric angle/side grinder. ~$15 and pretty quick. Not spotless bare metal everywhere but heavy rust and rust bubbled paint gone. I should be able to clean up and scuff nooks a little more by hand with scotchbrite pad then some sandpaper tommorrow or over weekend if I get time. A couple coats of primer should help even out and smooth it up enough.
It'll take lots of elbow grease but doing it with a wire wheel and wire brushes is the simplest and cheapest way.
I used to have to do this a lot working at Canadian Tire in Newfoundland (Rust with a capital R) because the rust would be so bad that the bead wouldn't seat. Copious amounts of bead sealer helped as well but isn't necessary with a tube tire LOL.
