I had the oil fill vent on my engine for a while and then went back to the valve cover/CDR setup. I think it really doesn’t matter where you vent the engine from, perhaps the oil tube is the best location, but the valve cover seems to work just as well.
At first, I went with a only a Mann Pro Vent. I found it would slightly pressurize the crankcase and had several small oil leaks, more like seeps. Just for a test, I temporarily rigged up the CDR to the oil tube vent and the oil leaks stopped, along with a slight vacuum in the crankcase. So, I changed back to the vented valve cover (not exactly an easy job) on the right side and went back to using the CDR in the stock location. I haven't had any oil leaks since. I'm thinking of testing the Mann Pro Vent with the CDR, but haven't yet.
I would decide what type of vent/CDR/open to atmosphere system you are going to run and then select the vent location that works best with your system. If you go with the stock CDR, its much easier to plumb using the valve cover. Plus, you are using all stock parts. If you choose something else, then maybe the vent tube would work. I think all NA 6.2/6.5's use the oil tube vent, but cannot say for sure.
One more thing, the NA's have a shield over the timing chain. I'm guessing its some sort of splash shield for the oil tube vent, but cannot say for sure.
Here are some pictures of the vents in use:
Here is the oil tube vent, plumbed to the Mann Pro Vent.
And the current, stock CDR setup
I had not changed the vented oil fill back to stock when this picture was taken.
