Heartbeat Hauler
A(ACLU) Agent Yoda
I just had my truck detailed and the detail shop "detailed" the underhood area. The following day I began having hard starts (slow engine turn-over). When it it did finally start the red battery light stayed on and the guages did not register, then after a few seconds the battery light goes out and all guages start working. I charged the driver's side battery with my Sears micro-prossessor hemi-powered charger checker. :skep: Anyways, the driver's side charged to 15.6 volts and the green light indicated "charged". Connected to the passenger side battery and the charger flashed "Check"...did not charge. So, Now I have one good battery and one suspect but it is most likely dead. Do these symptoms sound like the result of a suspect battery?
I forgot to say that the other night when the truck would not start the passenger side battery was really hot, like burn your hand hot, the driver's side was nowhere near that hot. Now I know the turbo is on the passenger side, but that battery was really hot!!
