I hate cutting an original wire harness and go out of my way to prevent it. I am not aware of any mates/connector that will allow OPS connector to plug into it. So, I made my own with an old OPS.
Used a tubing cutter to cut the body off cleanly.
The middle pin stayed attached so I cut it off down low with lots of pin to work with. The two outer pins will stay in the body. You need to grab them down low from the connector side and push them out. Be carefull not to bend them.
Soldered 16 gauge wire to the tips of the rear. Make sure you attach and solder it like show or the pin will not fit back into the body.
Wires with pins reinstalled.
I used "Goop" brand sealant to pot the wire inplace. If you use Goop only apply 3/8" or less and let that dry then come back with another layer, and so on until you have covered/insulated the pins/wires.
More to come in just a minute Have to upload the pictures.
