vdb11
Halfmoon Detroit #2
Hello all!
I have been reading up on this recently (like Jamie's thread) and I have a few questions.
I would like to solid axle swap my 92. However, I am on a VERY tight budget, I have a few questions for you guys.
If I find the axle at a good price, I will probably do the project, which means probably a 77.5-79 Ford Dana 44 instead of the 60. I have already found one at a decent price I just need to figure out what all I will need.
As for my use, I would like to lift the truck maybe 3-4 inches, leafs up front and probably blocks in the back. Is it even possible to do a swap and have factory height? I am not a crazy off roader. I do use 4wd a decent bit in the winter and on the farm. I may pull the truck once or twice a year, but nothing too harsh so I think the 44 will work fine for me.
Like I said, the budget is very tight, I am a poor college kid
As some of you have seen, I am also doing a rebuild/buildup of the motor too here soon.
For my application, can I use factory brackets and hangers from a mid 80s chevy? or anything else? I know there are kits out there from ORU and ORD and others but they are out of my price range and I don't mind doing something that isn't bolt-on and spending extra time doing it. I would like to get as many parts from the junkyard as possible to keep the cost of this project down.
Some of the other things I have seen I will need to address:
Driveshaft, I read a custom one needs made, but I also read somewhere that a driveshaft from an 80s chevy could work in my situation (not much lift). Any ideas?
Steering. I have also seen I need to do crossover steering, does that all need to be custom made or can I use any factory parts? I saw my steering box can be used, anything else? I guess some pictures of different steering set ups would be helpful, since I am unfamiliar with what I will need to do.
Other little things, like brakes, can I use all my original brake parts and just extend the lines? I don't believe I have ABS since I don't have the controller box under the hood on the driver's side. Any other things I am forgetting?
Thank you guys for all your help, I have been doing alot of reading and trying to make sense of it
Like I said, if I can do this project on the cheap then I will do it. I have the torsion bars cranked right now and the upper arms are almost touching the stops, plus I don't like the CV angles and the terrible ride ( I think my shocks are also shot), but my truck still sets too low for my liking. I have looked into IFS kits, but they are too expensive for me, and I have even thought about making my own IFS lift.
As I mentioned, I don't want anything crazy, like 3 or four inches at most of lift, stock wheels with either 265 or 285 AT tires. I like the way 90s Fords set, kinda high without being too high or impractical for what I need.
Thank you guys!
EDIT: I also saw mention of using a chevy axle and t-case (like the 205). What would be easier/less expensive? Any adapters needed for the t-case??
Thank you guys!
