mods feel free to delete this if this is against the rules.
Hey guys,
I recently had the privilege of helping the development process for a new PMD design. The company that I worked for is the same company that sells to dipaco, kieth, dorman, GM, and the rest of the smaller shops that supply PMD's, they're all the same.
The previous design as you all know had a lot of flaws. The new design is far superior. Contrary to popular belief, most of the failure issues were due to noise. Heat definitely helped this, but was not the root cause of the failure modes (especially run-away motor conditions). The main problems with the design of the PMD with the MJ15004 Transistors is that the transistor's collectors are common to their housing. This means that if they are mounted in the heat sink without the isolation pads, the heat sink cannot touch Vehicle ground or a short from (battery +) to ground will occur. This is why there is an isolation pad from the transistors to the heat sink and also as an extra safe guard, another isolation pad from the PMD heat sink to the remote heat sink (or pump) and anodizing on the PMD heat sink.
Because of this design, there is a lot of EMI generated on the heat sink from the high switching currents of the transistors. This creates noise in the whole system that otherwise would be mitigated if the heat sink were grounded. These high noise levels reduce the signal to noise ratio in the logic chips inside of the PMD.
The new design uses most of the same components, and is in the same housing, you wont be able to visually tell the difference without popping the lid off or bench testing it. The component grouping and the noise suppressing method is a lot better in the new design. The new design has passed multiple conditions that would otherwise have failed in the previous design.
I have played with, ripped apart, built hundreds of PMDs and did hundreds of miles of vehicle testing and I must say the new design is about as good as its going to get using those transistors. The overall design is a very challenging electrical problem, in most electrical systems you would suppress inductive noise (switching noise from the fuel solenoid), but in this scenario we are measuring the noise as a guarantee that the solenoid closed and sending this feed back signal back to the PCM so it knows how long the solenoid took to close.
I have been using this forum for some research and as an automotive enthusiast I know that if you are going to buy a new PMD you want the best one out there for your truck so I figured I'd let you guys know first.
thanks,
-hxtasy
and his responce to some questions
Originally Posted by Bison
Same loaf of bread in a diff bag will still be the same loaf.
What exactly would be different from the old style??
Why use the same PMD size and not going bigger and incorporate a remote mounted isolated heatsink to both tackle the heat and as you say noise.?
No it's a different loaf of bread in the same bag. To sell to GM, Dorman and et cetera so they can do OEM replacement it has to meet certain dimensions and performances.
The old design doesn't work correctly at certain frequencies, but you would not notice this in your truck because it is only under certain conditions that the PCM would send this signal (any frequnecy higher than 240 hz which is around 3krpm on the solenoid that is less than 50% duty cycle), You would be getting incorrect fuel timing with the old PMD. You can see this during a bench test and see that the new design does not have this problem. This is an indication that there is too much noise on the control signal of the IC inside of the PMD. this is evident in every PMD, the ones that fail are the ones that just have this noise problem worse.
Bigger is not better, a Standard MOSFET transistor you could get today could handle more current and have lower internal resistance (less heat), weigh less, and cost less than both of the BJT's in the current design. With the MOSFET though you would lose your feedback signal to the PCM.
I've already designed MOSFET PMD's and thought about using optical isolation to measure the reverse inductive kick, but it's just not going to be incorporated in production that is for older engines when company's already have the tooling made to bang out thousands of these PMD housings/parts a week; especially when the majority of the units out there work fine.
All the feedback circuitry does is tell you when your solenoid is going bad, it's really not worth having it in there because of all the electrical noise it creates but that is the specification that GM decided to have.
