chefmike
Not just a truck... a project.
I simply removed the two bolts holding the factory LP holder (black plastic). I ran the threaded rod u-bolt through these holes. No drilling. It was all hand tools. So it is mounted in the factory LP location, simple spaced out above the fittings.
The bypass fittings are PERFECT. It is nice knowing I can swap the factory style pump back in with two wrenches if needed. No tthat I forsee that need!
